07-06-2008, 02:43 PM   #1 (permalink)
rod123
idle surge
My 69 Torino has just developed an idle surge on it's 302 engine. The 650 holley is about 6 months on the rebuild. It was running great until a few days ago. I have not changed anything.
I checked all my vacuum lines today, they are ok. The car seems to run better cold and has no idle surge until warm. Being in south florida the electric choke is not hooked up or used.
I double checked the mounting bolts on carb, good and tight.
Other than pulling the fuel tank and cleaning out all the lines and replacing tank do you have any ideas?
Thanks Rod
Oh also need power window motor for the LH front and a set of power window gang switches on drivers door.
rod123 is offline   Reply With Quote
surge at idle cornhauler All Ford Techboard 16 03-24-2007 05:07 PM
efi surge at idle? torino501 All Ford Techboard 2 02-05-2006 01:50 PM
idle surge ujt389 All Ford Techboard 4 08-01-2005 04:40 AM
Big time help idle surge oldracer All Ford Techboard 1 07-25-2003 03:41 AM
Idle surge JaxTheDJ All Ford Techboard 1 01-20-2003 10:34 PM
