08-02-2008, 07:44 PM   #1 (permalink)
76grantorino
Engine Temp
I have a weinland stealth intake and I think my temp gauge is giving me an improper reading. So, I got a 2nd temp gauge and was going to hook it up to see if it gave me the same reading. I found 2 different spots to put the temp gauge sending unit. 1. Behind the distributor, hard to get to. 2. On top of the water spicket. I'm wondering if engine temp is just water coolant temperature? Also, there is a possible third spot. On one of the runners but I think this may be for air fuel temp.
76grantorino is offline   Reply With Quote
08-02-2008, 11:41 PM   #2 (permalink)
dbu8554
Re: Engine Temp
you mean thermostat housing right, should be a fine place to pull the temp from.
also engine temp is water temp
08-12-2008, 10:31 PM   #3 (permalink)
mdula
Re: Engine Temp
Engine Temp IS water coolant temp. That is at the top of the engine when it goes back in the radiator (water flows through the bottow side of the pump, and out the top of the manifold and back into the radiator).
Anywhere on the manifold, going through a water jacket should read the same.
'69 Ford Torino Formal Roof 302
Live for this!
mdula is offline   Reply With Quote
08-12-2008, 10:32 PM   #4 (permalink)
mdula
Re: Engine Temp
oops just saw this....yeah, hes right, what he said.
Live for this!
engine compartment temp juiceman39 All Ford Techboard 4 08-04-2006 06:10 AM
68 302 engine temp? dragtruckin All Ford Techboard 5 01-19-2005 11:35 PM
engine temp? gerzen All Ford Techboard 0 09-29-2003 09:05 PM
Engine temp. 66bluefb All Ford Techboard 5 01-12-2003 11:01 PM
engine temp? martyt All Ford Techboard 1 05-25-2002 09:04 PM
