08-16-2008, 09:06 PM   #1 (permalink)
myt4d
68 Torino Motor Mounts
Frustration is an under statement. Be aware of part interchange ability on the Torinos. We are running into problem after problem with 351w swap from our original 302...especially since you could not order a 351w c-6 9" set up in 1968. Even the hedders are a problem...we ordered hedders for a 351 and are trying to use them temporarily on the 302...should be the same...NOPE sure they will bolt up but they will not clear the firewall and floor pan area allowing the engine to come forward to its proper location. Yes they are Headman shorty 88650. Anyone have a set of 351 69 Torino motor mount bottoms?? We have the tops but would be willing to buy a complete used set if we can save a buck or 2.
Thanks.
Nashville Garage Contractor
http://midtngarages.com
myt4d is offline   Reply With Quote
08-16-2008, 09:09 PM   #2 (permalink)
gbic1
Re: 68 Torino Motor Mounts
351 W came in 69 and should be the same. Headers arent going to work because 351 is 2 inches wider and taller than 302.
Let it snow!
08-17-2008, 04:30 PM   #3 (permalink)
Ralphw
hmmm that is interesting,,,, i have a 68 torino that has the original 302 in it. I have since bought a 351w and was assuming i wouldn't run into any problems such as headers, mounts, etc. any other issues in this swap i could learn from?
http://www.shareaproject.com/pages/p...,p,430,00.html
Ralphw is offline   Reply With Quote
08-18-2008, 08:35 AM   #4 (permalink)
torino420
My car was originally a 302 and I didn't have any problems with the mounts when i went to the 351.
Headers, yes they usually are different because of the higher deck of the 351 which is about 1.3 inches taller then a 302.
69 Torino GT Formal Roof
420" Windsor
torino420 is offline   Reply With Quote
Need motor mounts for 1972 Ford Gran Torino....Help !!! 72biggreen Torino Pages 2 04-18-2008 06:38 PM
Motor Mounts for 460 in 73 Torino Mikelonis Torino Pages 15 02-21-2007 12:11 AM
Source ? 351W Motor Mounts 68/69 Torino LightningFastFords Torino Pages 3 05-09-2005 09:13 PM
Sources for 429/460 Motor Mounts for 72-76 Torino? Mikelonis Torino Pages 4 05-25-2004 05:55 PM
460 motor mounts in a \'73 Torino tim1859 Torino Pages 1 06-21-2003 10:34 AM
Powerhouse products
