Re: 2 ides
You could. You would have to cosider wiring, plumbing, gas / brake pedal, steering, motor mounts, cooling, shock tower vs motor width, tranny crossmember, transmision tunnel modified, shifter linkage, custom drive shaft, header fitment, exhaust.. etc... Never as easy as it seems. But could be done, but alot of custom work would involve. You could also carburate a 4.6 / 5.4. Alot of guys have put the mod motors (better yet 4v cobra 4.6, or lightning 5.4!) in their vintage ford. I beleve you would have to start by didching your front sumframe for a mustang II type, or late model ford type so the motor would fit. Maybe you could modify the oilpan, and make custom motor mounts. Ive kicked it around, I had a 04 lightning I raced, and would love to put it under the hood of my torino.
As far as coil packs? Are you talking about using coi on a vintage ford? I may be wrong but I think ford used EDIS on later model 5.0l explorers up to 2002. If that the case the components might swap, but I'd assume you would need the EEC or fancy wiring skills.
I like different thinking, but a $40 vaccume sounds like a safe cheap solution.
'69 Ford Torino Formal Roof 302
Live for this!
