Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Transmission Articles
08-28-2009, 07:00 AM   #21 (permalink)
bsmk
Re: Toploader Input Shaft Replacement
hi dennis i am trying to do the same thing to my top loader, but what clutch did you use my old set up has a 11 inch clutch i am trying to use my pressure plate.
bsmk is offline   Reply With Quote
08-28-2009, 10:09 AM   #22 (permalink)
dennis111
I use a special racing type clutch setup and just replaced the disc with a similar one.
I suppose that your clutch is a stock type and that you want a fiber-like stock type disc. For an 11" clutch disc that will fit the 1 3/8" large input shaft, I would check out small block Econoline (E-100 or E-150 series) trucks with a 4 speed. An 11" disc was used in some of them from the early 60's through the late 70's.
Here is a similar one that can be ordered through Summit: Hays 40-118 - Hays Clutch Discs - Overview - SummitRacing.com
Dennis
11.21@124.0 al naturale
My Racing Videos
HTML code is On
t5 input shaft 95cobra5.0 Mustang Pages (1979-1995) 1 12-01-2007 08:36 PM
Input shaft>?? Travis Rice C4 Transmissions 15 10-26-2006 07:24 PM
T-5 input shaft dave5257 All Ford Techboard 0 02-10-2005 12:45 PM
C4 with 26/26 input shaft gregaust All Ford Techboard 4 06-18-2003 09:03 PM
toploader input shaft 67Coug All Ford Techboard 8 07-06-2002 10:27 AM
