02-28-2004, 06:16 AM   #1 (permalink)
bigwann
pick up coil
I have a 79 F 350 w/460 ,problem is the last week I have had to replace the igntion module three times. what would cause this? wiring is in good shape ,not gdounding out. could the distributor be the cause of it? Need some help.
bigwann is offline   Reply With Quote
03-01-2004, 02:28 PM   #2 (permalink)
cdeal28078
pick up coil
Check the wiring inside the dist. to make sure it's not grounding out when the vacuum advance operates.
Clint
cdeal28078 is offline   Reply With Quote
