Gotta sell the dually beast
'86 F350 Crew Cab Dually
All black exterior, all red interior including aftermarket, damn expensive seats up front, C6 tranny, tinted windows, chromed stock steel wheels, dual tanks (59 gallons), straight body.
PS, PB, AC.
Engine:
460 with Milodon windage plate, 460 balanced crank, Boss429 rods with ARP bolts, SpeedPro 460 flat top pistons (about 9.5:1 comp), 285H Comp Cam, Ported heads, Inconel valves & new springs etc, hardened seats, Edelbrock intake(Performer), carb, gear drive cam set up, valve covers & air cleaner, new clevite bearings thru-out engine, new flex plate.
Head bolts & main bolts replaced with ARP studs, All engine covers & accessories top to bottom, front to back, inside & out, bolted on with 12 point polished ARP bolts, new Melling oil pump & ARP dizzy/oil pump drive shaft
Igntion: Full MSD including billet dizzy, 6A box, coil & MSD wires etc. Carter electric fuel pump. Dual remote oil filter conversion (not yet fitted). Cad 2 (gold) plated pulleys & bracketry
AutoMeter oil pressure, water temp & volt meters.
Aprox 4 hours on engine since overhaul. Current tags. Seriously hauls ass, top speed in excess of 130mph.
$6750.00 CASH.
Will consider parting out: Engine: $5500, Everything else $2500.
