10-14-2004, 11:53 PM   #1 (permalink)
junkyardjeff
5 speed overdrive for a 3/4 ton
Is there a 5 speed o/d trans heavy enough for a 3/4 ton that will bolt in older trucks,I just bought a 66 F250 that has a 4 speed with granny trans and I would like to find a 5 speed o/d to put in it for better gas mileage. I dont want to put in a wimpy trans as I will be hauling with this truck.
10-15-2004, 09:25 AM   #2 (permalink)
There has to be one out there but it's probably plugged into a diffrent style motor than what you want to put it on... That's usually the case for me anyway....
10-15-2004, 12:57 PM   #3 (permalink)
Luv70sFords
Do some internet searching on the Clark 5 speed. Its not a direct install, but its pretty damn close. Buddy put one in his 73 half ton 4x4.
10-15-2004, 01:39 PM   #4 (permalink)
66Fairlane
there the ZF S5-42(420 ft-lb capacity) and ZF S5-47(470 ft-lb capacity) The ZF S5-42 is in 88?-95 f250-350 and the ZF S5-47 is in 96-? F250-350. You can get it with a 302-351, 429-460, or 7.3 Diesel bell housing.
66Fairlane is offline   Reply With Quote
10-15-2004, 04:10 PM   #5 (permalink)
AlanCasida
A late model dodge/Chevy NV4500 5psd will fit behind your Ford with an Advance Adapters adapter. These transmissions have a cast iron case and the bellhousing is seperate from the trans unlike the late model Ford units. These go behind the 3/4ton-up trucks including diesels.
http://eshop.advanceadapters.com/com...=1097866551890
<font size=-1>[ This Message was edited by: AlanCasida on 10/16/04 3:12am ]</font>
AlanCasida is offline   Reply With Quote
