My 87 f-350 been sitting long time, wont start HELP
Hello All,
I have an 87 f350 custom dually, with a 460 eng, and a 4180 holley carburator with a 5 speed OD trans and an intank fuel pump.
Here's my problem!
I tried to start it, got crank no start, I then checked for spark, got spark at the dist cap and at the ign coil. still no start. I then took the fuel line off the carb to test for pressure, results, 0 pressure ( should have 8psi )? I then ran the fuel line into a 1 pint container and cranked engine for about 20 seconds, and it filled the 1 pint cup, ( I'm puzzled ! ) At this point don't know if the fuel pumps works or not (in-tank).
Let's keep in mind! I did rebuild the carb, replaced old fuel with new fuel and all new tune up components and
re-installed before all attemps above where made.
and it still wont start?
I then took cap off distributor to see if the rotor was truning, results, yes; it turned when cranking the eng. The armature and magnetic pick-up looked a little rusted and so did the inside wall of the dist. Then I checked the firing order results, OK
Tried it agian, no start. So I tried to prime the carb w/fuel and all I got was choking, hissing and some back-fire and no start. Now I'm thinking Timming! I'm going to bring the #1 piston Top Dead Center (TDC) then check to see if the dist rotor is facing the #1 wire on the dist cap, maybe that will work, and then I can fine tune once eng starts. I'm running out of ideas to try, I'm at a Lost here... Need all the help I can get for this one.
I also thought, that maybe for some reason, the catalytic converter has clogged up, and maybe thats way I'm getting hissing and choking??? DON'T KNOW! AT THIS POINT ANYTHING IS POSSIBLE [img]/phpBB/images/smiles/icon_mad.gif[/img]
AL
