11-16-2004, 05:56 PM   #1 (permalink)
gchero351
\'90 bronco 2 power window question
How do I go about getting the power window motors out of my 1990 bronco 2 to replace them ? the windows just kinda make noise. thanks.
gchero351 is offline   Reply With Quote
11-16-2004, 10:27 PM   #2 (permalink)
Drill out the rivits and replace with 1/4 X 20 bolts.
FE
11-28-2004, 07:16 PM   #3 (permalink)
fordtrucknutt
If you remove the plastic door panel and the liner, you will find 3 indentions where the electric motor is located. Drill the holes with a 1/8th pilot drill,then a 1/2 inch hole to access the 3 electric motor bolts. remove with a 5/16 inch socket or a 8mm metric socket. you do not have to remove the window or the regulator to repair or replace the electric motor. you can get a gear repair kit from Ford or a aftermarket supplier.
fordtrucknutt is offline   Reply With Quote
