12-07-2004, 04:14 PM   #1 (permalink)
BMackKC
99 4.0 SOHC Explorer Engine Noise
Hello all,
My Explorer has a very annoying clatter/chatter type noise coming from the front of the engine. It is intermittent (though frequent), and most often happens at low RPM/idle.
If I remember correctly, the source of the noise is the cam tensioner. It was replaced under recall a few years ago.
This looks like a fairly straightforward fix, once you get to it. I believe the book rate for this repair is 9+ hours, and I'd like to do it myself if at all possible.
O gods of all things great and Ford, will you bestow on me your sage advice? What sort of nasty things could happen if I'm doing this repair myself?
BMackKC is offline   Reply With Quote
12-07-2004, 05:45 PM   #2 (permalink)
deleted
I sent you a pm, but here goes again. If they did the full recall, (which I doubt, if the upper/lower intake 0 rings weren't replaced), then the 'kit' that needs to be installed(which has the 0 rings AND the cam chain tensioner upgrade kit), should be installed. There is also a pcm reflash for that setup.
Good luck, have fun.
Steve
drag79stang[img]/phpBB/images/smiles/icon_wink.gif[/img]
deleted is offline   Reply With Quote
12-15-2004, 06:36 PM   #3 (permalink)
GWF350
I believe this is the noise my '98 is making... I looked up recalls but didn't find the '98 listed. Is this just an annoying noise or a potential engine wrecker?
GW
GWF350 is offline   Reply With Quote
12-15-2004, 09:06 PM   #4 (permalink)
deleted
It's not so much a recall, (never was a recall), but just a 'if the customer complains about it, ford will fix it for free), *(if it's within the certain amount of mileage/years).
Just doing the basic MWO (modification work order), (army lingo), is a no biggie, but taking the front of the engine apart and replacing the actual cam chain tensioners takes/requires quite a few special tools.
As far as breaking other parts?..........the replacement of the upper intake and lower intake 0 rings will solve LOTS of driveability problems, (MIL on), and hard start/stalling/rough run conditions. BUT the noise ususually stays the same. (if you don't do the modification.
My .002
