02-22-2005, 12:56 PM   #1 (permalink)
calazo
1bb- to 2bbl -Same intake, can it be done?
Guys, would I necessarily have to replace the intake manifold on my 300 I-6 Bronco to upgrade to 2bbl carb from the stock 1bbl?. If not, how can the 2bbl be adapted to a 1bbl intake(putting in Holley/Weber...)? what parts are needed?, thanks a lot..![img]/phpBB/images/smiles/icon_confused.gif[/img][img]/phpBB/images/smiles/icon_confused.gif[/img][img]/phpBB/images/smiles/icon_frown.gif[/img]
calazo is offline   Reply With Quote
02-22-2005, 01:19 PM   #2 (permalink)
Luv70sFords
Im sure an adapter could be made, but squeezing it all through the single hole in the manifold would likely negate any advantages you are aiming for.
02-22-2005, 01:56 PM   #3 (permalink)
fats429
I found that the addapters work best when going down in size like for class restrictions or somthing like that . Trying to go up in size will more then likely cause fule flooding . Whats going to happen is by almost like funneling the air fuel mix into the smaller hole in the intake it will deatomise and flood the bottom of the intake.and you cant burn a liquid . I did this on a V8 with a addapter for 2 to 4 bbl
and olny went 2 miles befor the 2 bbl went right back on .
If you want more ponnies try to find a 4bbl intake and a small 4bbl carb this up grade is worth all the time and money it will wake your bronco right up
fats429 is offline   Reply With Quote
02-22-2005, 08:43 PM   #4 (permalink)
Calazo,
There was once a tri power setup made for the 140 and 200ci 6 cyl... You can ocassionally find them on e-bay... It was two extra 1bbl's put into the stock intake manifold...
Think on the looks on that puppy!!!
FE
02-22-2005, 10:44 PM   #5 (permalink)
Luv70sFords
The 140-250 stuff wont fit the 300. I've seen folks braze carb flanges on too a stock manifold to make a tri=power setup, but that takes a lot of fabrication. Does look pretty cool in the long run.
02-23-2005, 12:58 AM   #6 (permalink)
deleted2
There are a few adapters out there, try Clifford performance
02-23-2005, 11:47 AM   #7 (permalink)
Neal
If you are in no rush I have one of these 1 to 2 adapters hiding in my garage somewhere. I ran it for a while on my 300 when I couldn't afford the new intake and wanted to run my 2 bbl carb. It ran okay on my truck.
Neal is offline   Reply With Quote
Probe Industries
