08-27-2005, 05:09 PM   #1 (permalink)
xpauliber
Swapping: 400 to 302
I have a 78 F150 with a 400 and a 4 speed. I'm going to swap a 302 into it. What exactly do I need to complete the swap. Motor mounts, bellhousing, etc? Thanks
xpauliber is offline   Reply With Quote
09-11-2005, 04:09 PM   #2 (permalink)
junkyardjeff
You will need bellhousing,flywheel and clutch stuff for the 302 along with the motor mounts but the motor mount stands are the same as 302s. You will also need alternator and powersteering brackets for the 302 if you do not have them. Jeff
09-13-2005, 09:05 PM   #3 (permalink)
fordmonsta
ah hell the motor stands, or frame mounts as i call em they are all the same as far as i have had experiences with em, this is meanin all v-8 frame mounts excluding the 429-460 trucks, this only applies for the 65-79 trucks though
fordmonsta is offline   Reply With Quote
12-05-2005, 01:55 PM   #4 (permalink)
crzejkr
i have a 96 5.0 for sale , $800, 43k miles , msd full ignition, ford racing cap + distributor, located in florida , miami be exact.......interested , hit me up, leave a message, outa a 96 grandmarquis. used to be a show car
crzejkr is offline   Reply With Quote
