99 Explorer Overdrive light flashing
Off hand, I would assume there is a problem. Any idea if the trans was shuddering, slipping, etc? low or high miles?
the PCM {computer} is probably kicking out a warning something is not right.
If you go to an autozone, advanced, etc parts store, use their code scanner, and it should pin point the issue.
Could be a sensor, or could a blown gasket, hard to say without scanning for code.
When was the last time it was serviced? Rule of thumb with my stuff 2 years for complete trans flush, not just a filter swap and draining the pan.
Hope that helps.
