03-23-2006, 05:36 PM   #1 (permalink)
Torino500351C
ABS code, brake light fuse, help needed
Using the forums, and the books, I found out that I apparently have a problem with my factory trailer lights. The fuse for the brake lights blew, (and kept on blowing), and under the hood the fuse for the trailer backup lamps and running lamps was also blown. So, now that I 'know' where the problem is, how do I fix it? I don't know wiring too well, I haven't changed anything with the trailer lights or taillights or any lights in a long time. I dunno what to do. The only thing I've done recently was a DIY bedliner but that didn't mess with any of the wiring. Thanks in advance.
Oh, yeah, 95 f150 xlt 4x4.......pulled the code, says memory failure?...
Torino500351C is offline   Reply With Quote
03-31-2006, 01:23 PM   #2 (permalink)
rcm600
Are you sure the problem is with the vehicle not the trailer? Most often the problem is a short in trailer wiring. Can you try a different trailer?
rcm600 is offline   Reply With Quote
04-01-2006, 06:52 AM   #3 (permalink)
Torino500351C
Found out the problem was in my dealer recalled spped control stop switch. the switch and related servo went out. Thanks for advice tho
Powerhouse products
