96 Ranger OBD II questions
wipers are coming on due to a faulty multifunction switch, as for the lean code monitor the short and long term fuel trims, they shoud be close to 0% if the srt ft is off bring the engine up to 2000 rpm and see if it drops if it does it is probably a vacuum leak if not it is maf, ff, or possible electrical failure
