06-25-2006, 10:00 PM   #1 (permalink)
BrianD
1969 F250 engine swap
I have a 69 F250 HD 4x4 that needs a new motor. Right now it has a 390 FE in it, and I am getting a 360/390 from a 73 F150.
However, my truck has an automatic tansmition and the donor truck has a manual transmition. So, here is the question, can I take the donor motor and replace the flywheel with the flywheel from my automatic truck? Or do I need to get things rebalanced?
Another option, I am getting the whole donor truck, so would it be easier just to replace my automatic trans with the manual trans?
Is there anything else that I may need to be aware of?
BrianD is offline   Reply With Quote
06-28-2006, 04:33 AM   #2 (permalink)
My427stang
Just swap the wheels, no problem
For a high rpm racer you would need to disassemble and balance, but Ford didnt "balance" to the extent we do on a performance motor, you'll be well within tolerances
