Simple question?
I plan on rebuilding the TBird 5.0 (keeping TBird crank in) and getting rid of the 302. Glad to hear that I can use intake, carb, oil pan, and front cover from the 302.
When you say reuse I think you mean the TBird damper, TBird flexplate (to maintain balance) and TBird distributor gear correct?
If so, will the TBird flexplate bolt up to the C4 (Bronco) torque converter?
However, according to Chilton's '91 & '92 Cougar and TBird
both came with 5.0 HO engine (engine code T in VIN#).
Haven't taken off valve cover yet to confirm, but if it is roller motor does this change everything?
