09-03-2006, 09:09 PM   #1 (permalink)
kymadan
Anyone here put a 302 in a ranger?
Anyone here put a 302 in a ranger? I know it is a common swap, but I am wondering the best way to go about this swap. I want to put a Fuel Injected 302 HO into a 1986 4x4 Ford Ranger, it originally had the Fuel Injected 2.9L V6. Should I go with or without the knock sensor on the 5.0? If with, how would it wire into the rangers system. I know I need a mustang wiring harness, but it has to tie into the rangers at the firewall, preferably under the dash. Right? I also would like the Mass Air setup. Is that another problem I'll run into? Any help would be much appreciated.
kymadan is offline   Reply With Quote
09-04-2006, 06:36 AM   #2 (permalink)
64 TBOLT
http://www.therangerstation.com/
http://www.v8-ranger.com/forum/
09-04-2006, 04:20 PM   #3 (permalink)
66Fairlane
http://www.rangerpowersports.com/for...splay.php?f=12
66Fairlane is offline   Reply With Quote
09-04-2006, 08:37 PM   #4 (permalink)
kymadan
I had therangerstation.com, but V8-ranger.com and rangerpowersports.com are really becoming helpful. The main problem I am having is that it is hard to find the right things for a 4x4 ranger, everybody is mainly doing thwe swap in 2WD setups.
09-05-2006, 08:10 AM   #5 (permalink)
64TBOLT2
theres not much diff other than the front end and front cross member.You need a 5.0 double hump oil pan and pickup.You can use your stock motor mounts
64TBOLT2 is offline   Reply With Quote
09-05-2006, 10:40 PM   #6 (permalink)
kymadan
I could use the 6 cyl mounts for the 5.0?
09-05-2006, 10:44 PM   #7 (permalink)
64TBOLT2
yup. i used 4cyl mounts
09-05-2006, 10:46 PM   #8 (permalink)
kymadan
Whoa, I was about to buy 200$ mounts You dont thinkit will sit too low on the chassis and interupt with any 4x4 parts?
09-06-2006, 10:33 PM   #9 (permalink)
64TBOLT2
not if you use the 5.0 double hump pan
09-06-2006, 10:35 PM   #10 (permalink)
64TBOLT2
Probe Industries
