11-11-2006, 02:16 PM   #1 (permalink)
Billf
1977 f250 4x4
I need a very basic wiring diagram to rewire truck
Billf is offline   Reply With Quote
11-11-2006, 02:19 PM   #2 (permalink)
1977 f250 4x4
If you are going to re-wire the truck why do you need a diagram?
Lemme check my database... I'll be right back.
11-11-2006, 02:22 PM   #3 (permalink)
1977 f250 4x4
I use these guy's. It takes between 5 minutes and 1 day to get results but everything you could need is in there!
http://www.ahdol.com/
I don't have the one for the F series but I do have a Haynes manual or two that does show some decent diagrams but for $6 bucks or so you get to keep it forever!
FE
11-11-2006, 06:35 PM   #4 (permalink)
1bad6t
1977 f250 4x4
Maybe this will work http://www.humanspeakers.com/ford/wiring.htm
or go to http://www.tocmp.com/tOCMP/wiring/57.../fordindex.htm and use a Mustang or Falcon wiring diagram. It is basically the same as a pickup truck. I used a F-150 diagram to wire my delay wipers
