05-15-2007, 09:20 AM   #1 (permalink)
Elbeam2000
351 Water Neck
Need to change out my stock water outlet neck on my 351M.
It has a crack and is leaking but, I can't seem to find anything that fits. Can I use a neck from a 351C or 351W? What about a 400M? Need some help. thanks in advance.
Elbeam2000 is offline   Reply With Quote
05-15-2007, 12:39 PM   #2 (permalink)
Elbeam2000
351 Water Neck
Also need a 180degree thermostat that I have not had any good luck finding one. any help is great. thanks.
05-16-2007, 06:19 PM   #3 (permalink)
5851a
351 Water Neck
400, 351M, 351C, and 429/460 should all fit. It just depends on how you want the angle of the hose to come off it. There are several variations. You must use a thermostat for 351C/351M/400 as they all come with the bypass disk on the bottom.
05-28-2007, 06:06 AM   #4 (permalink)
revhead
351 Water Neck
Yep they all fit but just watch your dissy clearance , and good luck getting your part numbers for your radiator hoses. good tip take your old hoses to your parts supplier and match them that way.
revhead is offline   Reply With Quote
