06-09-2007, 09:53 PM   #1 (permalink)
MonsterMach
Effie Roll Pan Project
Here is the back of the truck with no roll pan ... the tail light wiring is all there and is 100% fuctional just had no place to mount the 84 Corvette tail lights I'll be using on the old girl.
This is the side skirt/extension ... it will need to be removed because the side of the roll pan replaces it and extends the panel to the bottom of the roll pan.
The Tail Lights will mount in buckets I made months ago which are 4 1/4" deep and just over 6" round so the frame rail in the PIC has to be worked around when I place the buckets in the roll pan.
This is the rear of the Effie with the buckets and the roll pan below (the buckets are more then 4 1/4" long in this PIC I had not yet cut them down to the desired length to set the depth of the lens in the roll pan panel.
I have more PICs but they are not processed ... the Roll Pan is ready to be welded up tomorrow, so there is quite a bit more to see.
<font size=-1>[ This Message was edited by: MonsterMach on 6/10/07 12:16pm ]</font>
