06-22-2007, 09:09 PM   #1 (permalink)
fasthauler
C6 kickdown lever adjustment
Anybody know the proper procedure for setting up the kick down lever on the 77 f250 C6 460?
I put on a 700cfm Edelbrock and would like to set up the lever properly.
86 Bird
77 F250
fasthauler is offline   Reply With Quote
06-22-2007, 10:50 PM   #2 (permalink)
gbic1
Re: C6 kickdown lever adjustment
You want the lever to be at its full travel under wide open throttle. Thats it!
06-24-2007, 12:33 AM   #3 (permalink)
fasthauler
Thanks for the response. The manual is very confusing on this adjustment. They say to put a .060 spacer between the adjustment screw and the throttle plate at full throttle and adjust the screw until it just touches the spacer. If you did that the kickdown lever wouldn't even activate.
I did find another site that said to set it so that there was a little play left in the kickdown lever at wide open throttle. I am going to set it that way and see if the kickdown responds ok. If not I will play with it until I get it right.
86 Bird
77 F250
06-26-2007, 12:31 PM   #4 (permalink)
fasthauler
I set it up with a little play in it at the full throttle position. About the .060 that the book talks about. It seem to work perfect. They just don't explain the procedure very well.
86 Bird
77 F250
06-26-2007, 04:27 PM   #5 (permalink)
chas319
On my Holley VS carb I used the stock C6 rod and put a larger pan head bolt on the carb kickdown lever. Then I used a medium spring over the bolt and double nutted it over the lever. That way I can adjust it and still always get full throttle.
82\' F150, 6\" lift, 35\'s, 4.11\'s and locked. C-6 shift kit. 347, AFR185\'s w/ all the other goodies.
93\' Ranger 4.0 Auto, stock daily driver.
chas319 is offline   Reply With Quote
06-27-2007, 12:13 AM   #6 (permalink)
fasthauler
The reason I posted this thread was to bring up the question of the proper procedure for adjusting the kickdown lever.
If you read the manual it states to open the throttle to wide open position and put a .060 spacer between the kickdown lever adjusting screw and the throttle and turn the adjusting screw until it just touches the kickdown lever. If you did it like the manual states the kickdown lever would never activate because the kickdown lever would need another .060 to even touch the throttle in the full throttle position.
They never mention the fact that the kickdown lever needs to be fully activated. It would have been a lot clearer if they had stated to back the fully activated kickdown lever with the throttle at wide open position by .060. Then I would have understood what they were saying.
I bought the Edelbrock 1483 adapter and bolted it right up to my 750cfm Edelbrock carb. I had to bend my throttle lever over to make up for the extra width created by the adapter, otherwise everything else just plugged in. I adjusted the kickdown lever to full on with the throttle wide open and then backed it down .060 and it seems to work great.
86 Bird
77 F250
Kickdown Lever Jetfixr320 C4 Transmissions 2 09-15-2006 04:56 AM
C4 kickdown lever question.... wildosvt01_OLD C4 Transmissions 20 03-03-2005 11:52 PM
shift lever linkage adjustment paintballtommy C4 Transmissions 2 02-10-2004 05:51 AM
Kick Down Lever, PLEASE HELP bulldog All Ford Techboard 15 10-09-2003 07:15 PM
C6 shift lever paxtonman All Ford Techboard 4 03-12-2002 04:05 PM
