07-02-2007, 04:14 PM   #1 (permalink)
stevec
power steering, but only a little
well, i just got the f150 running good and noticed that the power steering isn't working (the truck sat for almost 2 years). it was working properly when i last used it. already tried the "new" rebuilt pump on another truck this weekend so i know it works fine. i don't think it's a problem with bleading the air out .-but then again...
the steering is a bit stiff but not to the point that it would stall out the pump (could be a bad ball joint--or 2) or (the stiffness is coming from the steering box??) it will sort of work turning to the left (pulses and whines badly) but on the turn to the right it has nothing but a small whine and no help. there are no leaks, no foaming and the fluid is at the proper level.
yes it's the plastic tank pump.
again it's a '78 f150 4x4 351m,4spd, man. hubs etc.etc.
thanks again for all the help!
stevec is offline   Reply With Quote
07-02-2007, 05:21 PM   #2 (permalink)
Re: power steering, but only a little
Sounds like a worn out gear box....
I got a saginaw box you can buy but it's from a chebby... Oh, and it won't fit either...
07-02-2007, 05:36 PM   #3 (permalink)
stevec
figures. i guess i'll be throwing another box on this weekend. good thing i live about 5 minutes from a wrecker
when you put chevy stuff on a ford god kills a puppy.
09-18-2007, 10:38 PM   #4 (permalink)
dwbachor
Sometimes puppy's have to die. Check your axle U joints. if the are sezied it can play heck with your steering as I have found out.
PS the #### chevy### box does seem to work better.
"WRECKIN HAVOC" 76 F150 460ci.
dwbachor is offline   Reply With Quote
09-18-2007, 11:15 PM   #5 (permalink)
They're NOT chevy boxes to tell teh truth.... They are Saginaw steering boxes that Chevy uses...
They are nice though for sure!
09-18-2007, 11:15 PM   #6 (permalink)
P.S. That's ONE BITCHIN FORD you're beatin up on!
09-19-2007, 08:11 AM   #7 (permalink)
stevec
sorry guys for not getting back to you sooner (busy at work).
it was the steering box (siezed actuator) got it working fine now.
it'll be a cold day in hell before i use a chevy part on my fords. i want to keep them running.
09-19-2007, 10:35 PM   #8 (permalink)
dwbachor
Cool Re: power steering, but only a little
I stand corrected. The close ratio box I ended up with was from a ,well one of those.
PS Its alot of fun to play with.(and still runs)
Power steering to manual steering adapters fairlaniac All Ford Techboard 2 01-11-2006 05:49 PM
power steering pump fittings for a mustang II power rack gtnrb71 All Ford Techboard 1 06-10-2004 12:10 PM
Power Steering ? NMustang All Ford Techboard 1 05-04-2004 06:52 PM
power steering + 7,000 rpm = ? cobra All Ford Techboard 7 04-24-2003 01:05 AM
Power Steering, ATF or "Power Steering Fluid" thecougarguy All Ford Techboard 8 02-26-2002 06:45 AM
