07-09-2007, 07:43 PM   #1 (permalink)
Blue92F150
Rear End Swap
I am thinking of swapping my drum brake 8.8 rear end for a disc brake 8.8 rear end. I have a 1992 F150 and was wondering if anyone new what a good donor vehicle might be? I would like to find something that is pretty much bolt on after I take my old one out. Any suggestions is greatly appreciated.
Blue92F150 is offline   Reply With Quote
07-10-2007, 02:47 PM   #2 (permalink)
Blue92F150
Re: Rear End Swap
Somebody in here has to have done a rear end swap in this forum to achieve disc brakes! COME ON GUYS!
07-10-2007, 05:47 PM   #3 (permalink)
Luv70sFords
Re: Rear End Swap
I dont think disc brakes came on these trucks till the 97 model change. If the width is correct, and the rear speed sensor is compatible, you should be able to make something work. Might not be able to keep your ABS, but Im not sure.
Is there any particular reason you want discs?
Those that say it cant be done should say so quietly, so as not to disturb those who are doing it.
07-10-2007, 08:24 PM   #4 (permalink)
Edz64
Smile Re: Rear End Swap
The stock EXPLORER rear disc brake assembly should bolt right on.
The spacer that rests within the flange assembly might be the only obstacle. You dont have to pull/swap your entire rear end.Just brakes.
I have done it on a couple big bearing nine inchers with major modifications required , but the result is absolutely better engineering.
I cant believe no one else has responded......YET??????????
Check my pictures and you will see my last set up
Edz64 is offline   Reply With Quote
64 rear end swap 302burd Falcon Pages 2 04-04-2007 09:50 PM
Rear end swap? Sleeper All Ford Techboard 4 10-03-2005 08:58 PM
Rear End Swap dolomite41 Galaxie Pages 0 05-10-2004 09:06 PM
71 ltd rear end swap tjcrawfo Galaxie Pages 2 02-26-2004 04:21 PM
rear end swap lordviper13 All Ford Techboard 2 02-08-2002 05:05 AM
