07-23-2007, 10:34 PM   #1 (permalink)
buickbear
Talking trany swap c-4 to aod
I have a 1982 f100 with a 86 5.0lsb, and a C-4 or 6 tranny. I was wondering how hard it would be to put a Aod in? Also what aod do I need one form a mustang,vic,90s f150? My reason for the swap is I need to get better gas milage. Any info on this swap would be very appriciated.
buickbear is offline   Reply With Quote
07-29-2007, 05:05 AM   #2 (permalink)
5851a
Re: trany swap c-4 to aod
I would try salvage yard that had the whole truck and take all the parts from the block back to the rear end, shifter,start/reverse switch wiring, cooler lines ect. Throttle adjustment on the kick down rod is critical on aod's to keep from burning them up. It controls transmission pressure, and has to follow throttle movement from idle to wide open.
08-04-2007, 06:42 AM   #3 (permalink)
Blue92F150
I second the transmission kickdown cable importance, but it should be a farely easy swap. All it consists of is the transmission, torque converter, throttle bracket, shifter on the column or I think some companies (Lokar maybe) makes a floor shift setup. Like the previous poster said you should find a donor in a junk yard and just take the whole setup.
Blue92F150 is offline   Reply With Quote
10-09-2007, 10:15 PM   #4 (permalink)
buickbear
Ok could I use a TCI aod that has a manual valve body, and floor shift it?
Then all I would need is a torque converter? or would I need a different speed -O cable?
10-14-2007, 03:57 AM   #5 (permalink)
5851a
I reread that your engine is an 86, I have used the aod flexplate with the C-4 and it fits ok, but if you have a C-6 I don't think you can use the flexplate. You need a block plate or spacer plate that goes between the block and trans that matches trans and a flexplate that will match your engine balance and trans. I think the aod bellhousing bolts are longer on top than the other trans. I don't have any experiance with the manual valve body but would think it would be tiresome for everyday use. Speedo cable should be ok.
10-18-2007, 11:59 AM   #6 (permalink)
rkingston
You gotta use the TV cable set-up. Its different than a kick-down rod. It regulates line pressure based on position. Very critical to transmission life. Besides, the manual shifter would be OD, D, and L. Shouldn't be a hard swap if you have a C-4.
65 Mustang 289 - Forged Pistons RPM Air Gap 650DP AOD Tranny 9 inch trac-lock w/ 3.50 gears Solid Lift Cam Hooker Headers MSD Ignition Sub Frame Connectors
rkingston is offline   Reply With Quote
10-18-2007, 11:05 PM   #7 (permalink)
83broncodude
i have a ? about an aod. would a np208 transfercase bolt up to an aod, i have a c6 now and was thinking about swaping for an aod for a later project.
by the way, heres an article on a c6 to aod swap in a bronco.
Complete Overdrive Conversion for '78-'79 Ford Bronco .: Articles
83 FULLSIZE Bronco - 357W Comp Extreme 4x4 cam and other stuff that makes suck down gas faster than I can put it in.
83broncodude is offline   Reply With Quote
need help to identify between what trany i have c-4,c-5,or c-3 1quicGT All Ford Techboard 3 08-19-2006 08:19 PM
how much hp will trany take stang1994 C4 Transmissions 2 03-06-2006 12:55 PM
world class trany hyper1685 Late Model EFI Techboard 13 02-19-2004 10:46 PM
NEED TRANY HELP ON EXPLORER BOB PHILLIPS All Ford Techboard 3 12-21-2002 12:07 AM
C-4 trany ??'s 68 stang All Ford Techboard 19 07-30-2002 01:45 AM
