08-05-2007, 05:07 PM   #1 (permalink)
dotcentral
80-96 rear gas tank dimension
I have a 71 that is close to being a driver. Like most trucks of this era, I have the gas tank behind the seat. I'd like to remove it to get some more storage space in the cab. Some people have used a 60' mustang tank at the spare tire area, but the filler comes up through the bed floor. Not exactly practical if you have the bed loaded.
Some of the '80 to 96 (I think) trucks have a tank that mounts at the rear of the bed, with the spare tire mounted under the tank. The filler comes out the side of the box. If someone has this tank and can measure length, width, height I would appreciate it. I would like the dimensions of the tank, and also the width of the flange.
1971 F100 Sport Custom Shortbed 351W, 4V, Duals, AOD, Disc swap
1966 F100 Custom Cab longbed 352 2v, Disc swap
dotcentral is offline   Reply With Quote
08-06-2007, 08:24 AM   #2 (permalink)
Blue92F150
Re: 80-96 rear gas tank dimension
I just measured mine, it is approx. 6" High, 35" Wide (1" gap on each side in between frame), and 27" Long (front to back)). The diameter of the gas inlet is 2".
Blue92F150 is offline   Reply With Quote
08-09-2007, 03:24 AM   #3 (permalink)
5851a
Read something somewhere about the High Boy 4X4's using the Ranger tanks to remount their tanks in the rear. The High Boys have a narrower frame than the rest of the 73 to 79 line. Sorry I don't have any measurements. Check the Ford Truck Enthusiast site, lots of info.
08-09-2007, 03:25 PM   #4 (permalink)
dotcentral
I think I would have to use the high boy tank. My frame is about 33" wide, so it is a couple inches too narrow.
Blue 92, thanks for your help.
Rear End Dimension? buzzdrivr Fairlane Pages 3 06-29-2007 08:19 PM
Gas tank went bad 68 stang All Ford Techboard 5 07-21-2005 03:24 AM
63 gas tank 64 TBOLT Falcon Pages 1 05-19-2004 06:13 PM
351W Crankshaft dimension HELP jeffstar All Ford Techboard 4 02-03-2004 12:09 PM
Gas tank interchange, or custom tank? TheUnfairlane All Ford Techboard 3 03-25-2002 08:45 PM
