11-24-2007, 08:05 AM   #1 (permalink)
weerry
Question 75 F250 460 efi conversion
I have a 75 F250 with a 460, and was thinking of converting it to efi. The computer I would probably use is MegaSquirt. I need a intake for it since the late model efi intakes wont work. I thought about welding injector bungs. Has any one done any thing like this?
Derek
weerry is offline   Reply With Quote
11-24-2007, 10:27 AM   #2 (permalink)
KULTULZ
Post Re: 75 F250 460 efi conversion
The OEM intake will work. There is an adaptor available to mount a 4 hole (down draft) or single side mount (side draft) throttle body. You could then retain the OEM FI and EEC-IV. You would have to use the FI heads of course.
[FONT=Century Gothic][/FONT]
11-24-2007, 08:37 PM   #3 (permalink)
weerry
Thats just the thing I would rather not change the heads, because that means finding a set of heads. Which will raise the overall cost. Correct me if I am wrong the ports of the efi intake are different than the carbed version. I might be able to weld to the port and reshape it to match the older ports.
11-25-2007, 12:59 AM   #4 (permalink)
KULTULZ
Yes, they are very different and (IMO) wouldn't be worth the effort to match regular heads. It was just a thought.
11-25-2007, 01:05 AM   #5 (permalink)
KULTULZ
Here is the tech info you need to get started-
http://www.fordmuscle.com/archives/2...sion/index.php
1972 F250 radracing Truck Forum 3 07-26-2007 11:00 AM
1991 F250 Mass Air Conversion alchee Truck Forum 1 03-27-2007 06:45 AM
\'87 F250 4x4 ShotRod64 Truck Forum 0 11-18-2006 02:39 PM
72 F250 2wd differential dsouza Truck Forum 0 05-24-2006 12:43 PM
F250 Frontend joyenter All Ford Techboard 8 06-25-2002 05:40 PM
