12-30-2007, 12:09 PM   #1 (permalink)
AquaTortuga
1983 351 truck flywheel on 88 302 roller motor
I used the same flywheel off of my 351 on this late model 302 injected motor which I put a carb on. I am wondering about my tech advice as it has a shake/vibration to it between 600 and 1500 rpm. I have cycled through every vacuum and ignition possibility (I wont list all but I am experienced in basic induction and ignition stuff). I am left pondering if I need to change balancer and or flywheel. HELP! This truck is so close to being right and it sounds great. It just has a vibration at low speed like a counterweight issue.
Basically I took the 351 out of my 83 F250 and had a deal on this 88ish 302 injected motor out of a Crown Vic. Yes, Im wishing I would have just rebuilt the 351 but....oh well.
AquaTortuga is offline   Reply With Quote
12-30-2007, 09:01 PM   #2 (permalink)
AquaTortuga
Re: 1983 351 truck flywheel on 88 302 roller motor
Well from reading all the posts it looks like I need the 50 oz flywheel from the newer motor to get this engine silky.
12-31-2007, 01:11 AM   #3 (permalink)
KULTULZ
Post Re: 1983 351 truck flywheel on 88 302 roller motor
Correct.
TECH NOTE;
Small block reciprocating assemblies have some balance. The compact lightweight crankshaft itself does not carry enough counterweights to achieve zero balance. Extra counterweight is cast into the flywheel and harmonic balancer bringing the entire assembly into neutral balance. Early engines use 28.2 oz.-in. external balance, while 1982 and later engines use 50 oz.-in. flywheel and 34 oz.-in. damper external balance. All 351W engines use the early style 28.2 oz.-in. external balance.
[FONT=Century Gothic][/FONT]
390 truck motor 6bigdaddy Mustang Pages (1965-1973) 4 08-22-2007 07:26 PM
Usable Truck Motor Fordota Truck Forum 4 06-07-2007 08:55 PM
what is the hp of a 74 460 4bbl truck motor in a truck jtmnoxville All Ford Techboard 1 01-07-2005 07:05 AM
77 460 truck motor, into a 69 mustang fastback? galaxierace All Ford Techboard 3 09-17-2004 01:00 PM
351W into 79 truck - what motor mts stevefretz Truck Forum 7 04-19-2004 02:53 PM
