01-06-2008, 02:35 PM   #1 (permalink)
stevec
changing the rear seal on a 351m
o.k. guys and gals, i have a 79 f150 4x4 with (of course) a 351m,4spd tranny and a big old leaky rear seal (barley starting to leak) i have changed out a few rear seals on various trucks (4x4's mostly) without pulling the engine out.
that being said i was looking at everybodies favorite manual (haynes, bleh) and it says i need to yank the engine, loosen all main caps etc. etc. .
my question is, can i just pull the pan in the truck, (i have had it off like that before), and remove the rear cap and change it? or do i need to call a friend to help pull the hood off?
yes the bottom end is fine, it's just age eating at the seal. thanx!
stevec is offline   Reply With Quote
01-10-2008, 04:53 AM   #2 (permalink)
stevec
Re: changing the rear seal on a 351m
wow i'm quite suprised nobody has an answer for this...
01-10-2008, 06:57 AM   #3 (permalink)
FALCONAROUND
I think that may be a 2 piece seal which as you know you can do through removing the oil pan
Call the parts store
When my Gecko is broken, does that mean I have 'A REPTILE' Dysfunction?
01-10-2008, 08:05 AM   #4 (permalink)
stevec
yes it is a 2 piece seal. it just funny that all the other manuals i have say to just pull the pan and cap, and this particular manual (but only for the 351m) says i have to pull flywheel, loosen all main caps and slightly lift the crank to change it out, but only for the 351m.
i'm going to give it a go this weekend anyway and see if it can be done, i think it can. even if i have to pull the engine, it only takes an hour or so with a couple of friends, beer, pizza....mmmmm pizza.....
01-10-2008, 08:20 AM   #5 (permalink)
FALCONAROUND
Cool beans
You can Doo eeet!
Changing Rear Seal - 289 1965Comet All Ford Techboard 8 12-23-2006 08:46 AM
Changing rear diff fluid jeffstar All Ford Techboard 2 05-21-2006 06:31 PM
Changing out a rear end - is there anything I am forgetting ? lgh1157 Galaxie Pages 3 06-25-2005 08:51 PM
Changing a rear seal on a Top Loader.... MightyMach All Ford Techboard 6 01-14-2003 09:38 AM
driveshaft length when changing from a 7.5 to a 8.8 rear BBCFORD All Ford Techboard 8 03-20-2002 01:49 AM
