01-24-2008, 09:16 PM   #1 (permalink)
torino460gt
88 F-150 clutch help
ok im workin on a buddys 88 F150 300 6cyl 5speed (4speed w/overdrive) and once we pulled it up from the bone yard the clutch goes to the floor and stays..we replaced the line because it was broke open pretty bad and u can pump the pedel with the cap off and nothin no bubbles no sign of life..we poped the line off by the the trans and pumped and it would spit a drop or 2 of fluid but not much pressure...think it just needs a new slave cylinder?????
thanks
logan
big block ford rules all!!!!!!!!
torino460gt is offline   Reply With Quote
Next hydraulic clutch problem... clutch not disengaging 67greengt All Ford Techboard 3 07-12-2006 01:26 AM
Next hydraulic clutch problem... clutch not disengaging 67greengt Mustang Pages (1965-1973) 1 07-11-2006 09:19 AM
Changing mechanical linkage clutch pedal to cable clutch sharpshot71 All Ford Techboard 5 02-03-2006 06:28 PM
Clutch pedal sticking to the floor at hi revs -Anderson Ford Motorsport Hi-Rev clutch ville Late Model EFI Techboard 7 02-14-2005 04:48 PM
Adjusting the clutch: Throwout Bearing and Clutch Fingers! MightyMach All Ford Techboard 5 12-27-2002 07:38 AM
