02-07-2008, 07:47 PM   #1 (permalink)
scooba_guy
351W motor oil pressure
I have a 1990 F-150 4x4 reg cab long box 5.8L. 38,000 original miles. 2 years ago I did a cam swap to the Comp cams EFI cam for my motor and put on some headers and flowmaster american thunder exhaust. I put in a high-volume oil pump after having distributor gear failure last summer. A sliver of metal wedged itself in the oil pump housing stopping my oil pump shaft and shearing off the distributor gear pin. At that point I didnt have the oil pressure gauge installed but put it in this summer just for kicks. just a summit 270 deg sweep gauge. $20. My oil pressure at cold start on 5w-30 quaker state motor oil is around 45psi. At hot idle its about 20 and at hot on the highway its about 30-35. I think thats kinda low for this motor.
Anyone have any clues or insight as to why this seems low to me? I live in the U.P. of michigan and its been subzero up here so thats why I am using 5w-30. In the summer I use 10w-30. Did I make an oops by putting in a high-volume pump? After my event this summer I put in an MSD billet distributor with an iron pump gear.
Any help or suggestions would help.
scooba_guy is offline   Reply With Quote
02-07-2008, 08:21 PM   #2 (permalink)
forthman
Re: 351W motor oil pressure
Maybe a bit low compared to what i see on my 351w. (393)
The gage could be off a bit.
But 10lbs for every 1000k hot is about right. So just cruising i think 35 lbs is ok.
1966 Stang Coupe Org. 6 cyl. 351w,Sealed Power Hypers, ARP bolts,Total Seal rings,Eagle H-beams rods,Balanced,Hedman long tubes, Pro Comp 2.05/1.60 Heads, Shaft roller Rockers, Victor Jr intake, Holley 750 DP, Ed Nix Custom .600/.600 254/258 @.050 Solid Cam, Crane solid roller lifters,Richmond 4.11, Strange mini spool, Modified C4, 3500 stall, Redneck Transbrake, B&M Hammer shifter, Shelby lowered, Pro Comp 6Al system. Mickey Thompson 275/50 Et Street Drag radials.
02-07-2008, 08:24 PM   #3 (permalink)
scooba_guy
Thats the thing; at idle my oil pressure is at about 20 and then rises to about 30-35 with RPM but never goes over that even when the engine is hot all the way up to 4500rpm. I've been reading some threads on faulty pressure bypass springs in the melling oil pumps. Is it possible this is an issue? Could I have a stuck bypass spring?
03-11-2008, 09:16 PM   #4 (permalink)
doug351
Whether it's low or not is not really the question I think. The question is :is it a problem or not? I don't see a problem with that kind of oil pressure. You might want to look at it this way: a high volume oil pump doesn't necessarily mean you have to have high oil pressure. You have a thin oil in there, and you may have some larger than ideal bearing clearances. But the fact that it never drops is a sign that you are getting good FLOW and 60psi doesn't do you any good if it drops to 10 or the oil isn't getting to where it should. BTW, if you were to throw in a heavier motor oil and your oil pressure were to rise significantly, it would point to a bearing clearance issue, whereas no change might indicate a pump change could raise pressure.
doug351 is offline   Reply With Quote
Oil Pressure Issue on 351W Murff All Ford Techboard 32 08-13-2008 12:20 PM
351W Oil pressure port? krehmkej All Ford Techboard 2 03-21-2007 03:27 PM
too much pressure in motor? saleenstang88 Late Model EFI Techboard 2 06-26-2006 09:17 AM
Too much pressure in motor, NEED HELP?? saleenstang88 Mustang Pages (1979-1995) 1 06-25-2006 08:24 PM
too much pressure in motor? saleenstang88 Late Model EFI Techboard 0 06-25-2006 11:19 AM
