03-27-2008, 06:22 PM   #1 (permalink)
evil66
Thumbs up 351M, EGR/ non-EGR
Thanx for the info!!!!! I'm going non-EGR!!!!!
evil66 is offline   Reply With Quote
03-28-2008, 10:18 AM   #2 (permalink)
Mikelonis
Re: ?? 351M, EGR/ non-EGR??
If you have a 351M with an EGR (probably does if it's bone stock) then it'll have a plate between the carb and intake with a bunch of ugly vacuum ports and heat risers. Since you have a 66 truck I just see no reason to have an EGR on there. Buy the non-EGR edelbrock set-up and toss all your current associated EGR equipment. I did it here in this article.
http://www.fordmuscle.com/archives/2...Neck/index.php
See specifically caption #3 under "Simplifying the Beast". That's the EGR plate.
03-28-2008, 11:32 AM   #3 (permalink)
haroldrussi
I reinstalled the EGR valve on my 89 460 without any problems. It should help a little with gas mileage and emissions.
haroldrussi is offline   Reply With Quote
03-31-2008, 11:59 AM   #4 (permalink)
forddude
Originally Posted by evil66 View Post
I have a '66 F100 with a ('76) 351M; I have recently been shopping the Edelbrock catalog to build the top end. Looking at the carbs and intakes they have EGR or non-EGR. What's the differance?? How do I know for sure if mine is EGR equipted or not? If Iam going to rebuild the motor does it matter if I get either or? Any help or info anyone can give would be appreciated!! Thank You!!
in a '66 ford........I wouldnt bother with the egr. get yourself a non-egr, dual plane intake, throw a decent size double pumper on it and HAUL ASS!
Your ride is you, You are your your ride.
___________________________________
1966 Ford Galaxie. Frame off rebuild in progress.......and pieces.
forddude is offline   Reply With Quote
351m from 400? jeffh All Ford Techboard 4 06-29-2007 02:07 AM
C4 on a 400/351M? polkat C4 Transmissions 15 11-08-2006 07:13 PM
351m to 390 going Hi-Pro kjaxntn Truck Forum 5 09-28-2004 09:30 PM
351m macoliver All Ford Techboard 5 01-29-2004 01:35 PM
351M and C windsoreight All Ford Techboard 3 11-05-2002 10:53 PM
