04-04-2008, 08:13 PM   #1 (permalink)
galaconocous
I6 to a 351w swap
Hi everyone, i am building a 89 ford f-150 that has a straight 6 fuel injected and putting a 351w carburated in it, i know i will have to install new motor mounts, transmission/motor, shift linkages and wiring for the msd 6a, but do i got to get a driveshaft made, new radiator?even if i got electric fans, anyone did this before all help is helpful, thanks room,
galaconocous is offline   Reply With Quote
04-08-2008, 08:05 AM   #2 (permalink)
pedal2themetal45
Re: I6 to a 351w swap
Yes on the drive shaft.. most likely they'll be different ends as well as the leanght. Radiator you could try it and see how it runs it would be easy enough to change if you had to..
tim
64 International 4dr. truck w/466 14.5 1/4 @ 93 mph.
http://i82.photobucket.com/albums/j272/pedal2themetal45/64%20international%20build/mytruckatrockies.jpg
05-10-2008, 01:33 PM   #3 (permalink)
BigMo
You will deffanatly be running at an overall higher rpm with the 351, you could probably try using the same radiator but you may want to be on the safe side and get one with a bigger tube size for a higher volume of water flow
BigMo is offline   Reply With Quote
05-17-2008, 01:48 PM   #4 (permalink)
forddude
I have an '89 F150 XLT Lariat with the fuel injected 5.0/c-4. you could probably find the right driveshaft complete at a local boneyard. I'd go with a bigger radiator for the extra water volume and flow, I mean , would you be stupid enough to rebuild an engine and then put a used oil pump in it? No one is that stupi......nevermind. My truck had a blown I-6 in it when I got it and the swap wasnt all that difficult. I lucked out and "found" a huge 4-core radiator out of an '88 3/4 ton while I was scrounging motor mounts and other stuff. I'm running the c-4 that was in my truck when I got it so I didnt need to swap driveshafts and flywheels and crap. I do, have one question......is there some reason your going from fuel injection to a carbed engine when your truck is probably already equipped with TPI?
Your ride is you, You are your your ride.
___________________________________
1966 Ford Galaxie. Frame off rebuild in progress.......and pieces.
forddude is offline   Reply With Quote
351w swap 64galwgn All Ford Techboard 5 10-03-2007 05:20 PM
351w swap 69stang69 Mustang Pages (1965-1973) 3 10-28-2006 10:49 AM
351W swap falken All Ford Techboard 4 03-22-2004 10:35 AM
351W swap Foxfire All Ford Techboard 1 08-14-2003 08:43 AM
T5 Swap on a 351W labzerpa All Ford Techboard 8 07-16-2003 05:45 PM
