04-11-2008, 09:02 PM   #1 (permalink)
BMackKC
99 Explorer--no heat/ac blower
Probably a no-brainer here, but just want to double-check before I buy a new blower motor.
No fan whatsoever on the front unit...rear works normally. Disonnected the leads, and a voltmeter connected to blower leads show ~11.5 V when the system is on, and 0 when the system is off. Bad blower motor, right?
Also, I would have expected the voltage to vary when I adjusted the fan speed...but it stayed more or less constant. What's up with that?
thanks for opinions...
BMackKC is offline   Reply With Quote
04-11-2008, 10:33 PM   #2 (permalink)
gbic1
Re: 99 Explorer--no heat/ac blower
Motor and you may need a resistor, both are common problems.
]1964 Galaxie 500 fastback 352 Auto.
04-12-2008, 08:36 AM   #3 (permalink)
BMackKC
gbic1
Where is the resistor? And how do I test it? Would I still have 12V to the motor with a bad resistor?
Thanks again!
671 BDS Blower FATNFAST Parts for Sale 2 03-12-2008 04:20 PM
Blower vs. Stroker torkair All Ford Techboard 26 10-06-2007 05:55 AM
460 with 6-71 bds blower joe4g63 Truck Forum 2 04-29-2005 10:36 PM
blower cam ? speedfreak All Ford Techboard 3 06-04-2004 09:41 PM
B&M Blower...for what? boss302 All Ford Techboard 5 06-24-2003 10:35 PM
Holley
