05-10-2008, 01:24 PM   #1 (permalink)
BigMo
Gearing to go with a 393 stroker?
I am building up a 393 stroker to drop into eather a Bronco or a single cab, short bed, F-150. I am going to raise up the suspension enough to fit eather 44"-54" super swamper boggers on the truck. With that set up I was wondering what transmission gearing, rear end, and front diff. gearing set up would be best? I plan on replacing the stock axles with bigger beefer ones, I'm not too sure on what to use for that eather (the front axle is deffanatly going to be solid). I just don't want anything to snap between the enging and the tires when I'm rompin' on it in thick mud. I am primarly gong to use the truck for mud bogging. With those big tires I was also wondering if I should consider axle extensions for better tire clearance and a wider wheel base?
BigMo is offline   Reply With Quote
Gearing valleyfirearms All Ford Techboard 5 05-02-2008 05:55 AM
3.73 Gearing DominickSch All Ford Techboard 5 06-29-2007 11:21 PM
gearing 1bad67cat All Ford Techboard 0 09-25-2004 01:39 AM
Gearing question voot61 All Ford Techboard 2 01-06-2004 12:37 AM
gearing vrs revability? andwrong All Ford Techboard 3 02-10-2002 01:32 PM
