05-12-2008, 05:01 PM   #1 (permalink)
Mike545
2.3l power?
i know it might be lame, but just got a 94 ranger with 5speed and 2.3l, driver, how do i get little more power/ gas milage? no i dont want nitrous or turbo,
no cars anymore
2003 f150 fx4
Mike545 is offline   Reply With Quote
05-13-2008, 08:02 AM   #2 (permalink)
pedal2themetal45
Re: 2.3l power?
Check out these guys at the rangerstation
4-Cylinder (2000 & Older) - The Ranger Station Forums
05-15-2008, 09:38 PM   #3 (permalink)
3ondatree
Re: 2.3l power?
A good friend of mine builds 2.3L motors. He once told me that the head is the first thing holding that motor back. Something about the way they routed the ports in the casting is restrictive to flow. Only so much can be done with these heads as far as enlarging and smoothing the ports I guess, which is why most guys force-feed them with a turbo.
I think the later Rangers had better intake manifolds and throttle bodies (maybe off of a 2.5L), you might check into that.
I know that the stock computer also de-tunes that engine (to help engine last longer). I don't have a clue what's out there in this department, but it might be worth checking into.
I sold my 2.3/5spd for $200 and dropped in a 302/C4. That didn't help save gas though.
Ryan
-'61 Falcon Futura 2-door, 200ci I-6, 17x8" Bullitt wheels
-'78 F-150 Ranger 2wd, 302ci V8, C4 trans
3ondatree is offline   Reply With Quote
05-15-2008, 10:22 PM   #4 (permalink)
Re: 2.3l power?
Advance the timing about 5 to 8 degrees...
That will give it a teecy bit of pep.
05-16-2008, 05:34 PM   #5 (permalink)
3ondatree
Re: 2.3l power?
Exactly, but that's the problem with the stock computer/ignition on those trucks... it stops advancing the timing after 4000rpm! I think it actually retards the timing if I remember right.
Ryan
06-10-2008, 02:15 PM   #6 (permalink)
94_ranger
Re: 2.3l power?
Here is a video of my old Ranger before I sold it :*( to fund my Capri. I got about 175HP out of it N/A, and that was with standalone engine management (Megasquirt), Esslinger cams, big vlaves, ported head, 2.5 internals, custom CAI, custom exhaust, etc. The video is with old tires and worn out shifter bushings. I'm giving it about 3/4 throttle the whole time (no traction).
94_ranger is offline   Reply With Quote
Power Windows and Power Bench Seat 64GalaxieHTOP Galaxie Pages 10 03-24-2008 10:15 PM
1972 GTS, brake pedal, non-power assist vs power assist eliteman76 Torino Pages 0 05-22-2006 07:31 AM
power steering pump fittings for a mustang II power rack gtnrb71 All Ford Techboard 1 06-10-2004 11:10 AM
Master Power Power Brake Conversion 69convert All Ford Techboard 10 09-19-2003 03:37 PM
At which power level does 2,5\" dual exhaust start to restrict power output? ville All Ford Techboard 15 04-23-2003 11:35 AM
