05-15-2008, 09:07 PM   #1 (permalink)
3ondatree
Question Power steering leak- Hard to fix?
Hey guys, I've got a '78 F150 Ranger 302/C4 with an intermittent power steering leak. Usually it leaks worse the further I drive. It's not bad or doesn't leak at all after short trips. As far as I can tell, its dripping out of the steering-arm shaft seal. I haven't had time to look at it closer, but if that is it, is it a difficult task to replace this seal?
Any suggestions?
PS-
I almost forgot to mention, IT JUST ROLLED 300,000 MILES!!!
Ryan
-'61 Falcon Futura 2-door, 200ci I-6, 17x8" Bullitt wheels
-'78 F-150 Ranger 2wd, 302ci V8, C4 trans
3ondatree is offline   Reply With Quote
05-16-2008, 06:23 AM   #2 (permalink)
KULTULZ
Post Re: Power steering leak- Hard to fix?
Any suggestions?
PS-
The sector shaft seal can be replaced on the vehicle. The trick with 300,000 miles on the chassis is that the sector shaft bushing (and possibly the sector shaft itself) is worn.
[FONT=Century Gothic][/FONT]
05-16-2008, 05:42 PM   #3 (permalink)
3ondatree
Is this a difficult task best accomplished at the shop? Are there any special tools required (ie for removing the seal, etc.)?
Ryan
05-17-2008, 01:20 AM   #4 (permalink)
KULTULZ
You can replace the seal on the car. Remove the pitman arm, dust seal and the oil seal will be visable.
You can remove it with a seal removal tool (pick). There is a special service tool(s) to do all of this but usually you can find a large socket (or fashion a driver out of pipe with cap) to knock it in. A trick (if the sector shaft and bushing is OK) is to install two seals (piggyback).
A reman box should not be that much.
If you feel uncomfortable doing it, a shop should not charge much over an hour to do it.
05-21-2008, 05:05 PM   #5 (permalink)
3ondatree
Thanks! That doesn't sound bad - I just didn't want to rip into it in the driveway and realize I was in over my head.
Ryan
Power steering leak brentville Galaxie Pages 1 09-09-2007 05:54 PM
power steering hard line Neal All Ford Techboard 2 04-16-2005 09:59 AM
Power Steering Leak beegshot Truck Forum 5 05-18-2004 01:31 PM
Power Steering leak beegshot All Ford Techboard 1 05-06-2004 06:40 PM
power steering leak sjtdrum All Ford Techboard 4 07-12-2002 05:07 PM
Holley
