05-21-2008, 02:13 PM   #1 (permalink)
kaboom10
A strange misfire
I just got a strange misfire today. I had a fouled plug with my original plugs and drove it hard and that disappeared. This is a recent set of platinums that were installed. I also had a set of Accel COPs put in at the same time. Maybe have 2000 miles on everything. It doesn't throw a code yet but you can feel and hear one cylinder isn't up to snuff. It doesn't show on the vacuum guage as anything burnt like a valve. It's rather a steady reading with the idle RPM not varying more than 10 rpm either side of 580. To me it feels like something on the verge of quitting functioning. Any ideas? 02 5.4L F-150
02 F-150 that just LOOKS stock,Trans shift kit,4.56 gears w/ Detroit TruTrac, LiveWire Pro Racer Package tuned. My baby: http://i48.photobucket.com/albums/f240/kaboom10/100_0291.jpg
kaboom10 is offline   Reply With Quote
05-21-2008, 03:36 PM   #2 (permalink)
bassman97
Re: A strange misfire
Could be your injector on that cylinder is going.
05-21-2008, 03:47 PM   #3 (permalink)
kaboom10
Brand new set of Accel injectors. Put in a few weeks ago.
05-21-2008, 03:54 PM   #4 (permalink)
Check your coil boot on that cyl. the boot might be allowing the spark to be shorting to the wall's...
05-21-2008, 03:59 PM   #5 (permalink)
kaboom10
Thanx. They're brand new but I'll give that a look see.
05-21-2008, 04:11 PM   #6 (permalink)
New ACC injector could be bad. Hangnig open and fouling the plug, OR not opening, OR it has debris from the assembly blocking the flow of fuel......
New/Bad get's past QC all the time....
05-21-2008, 04:26 PM   #7 (permalink)
kaboom10
If that's it I'm gonna be pizzed. I haven't gotten any DTC codes which confuses me.
05-28-2008, 01:19 PM   #8 (permalink)
kaboom10
I found the problem finally. It was #3 COP. I took resistance readings from the contact point spring for the spark plug to either of the input terminals. Accel is a reading of 6.3 on the 200k scale and compared to a stocker of 5.2-5.6. The third coil I replaced read 4.3 and I figured that was the culprit before I started the engine to try it. This reading confirms why it wasn't a complete misfire. I'm just still used to complete misfires from single coil setups. I'm not at all a chebie fan but the coil per cylinder setup is ez as far as troubleshooting. Thanx to all for the inputs.
05-28-2008, 01:23 PM   #9 (permalink)
FALCONAROUND
Glad you got it! And I was kind of close with the booot thing
Signature contemplation still in legal process so as not to step on any toes... ;)
05-28-2008, 01:31 PM   #10 (permalink)
kaboom10
The bad COP left the boot on the spark plug when I pulled it out. About all I can see is there is a different amount of windings between stock and Accel. Boyit's fun hearing the tires again.
breaking up///misfire carnutt331 All Ford Techboard 4 07-01-2007 03:42 AM
Misfire at 2500 rpm Yaap All Ford Techboard 9 03-23-2006 12:31 PM
Strange 66 289 misfire jackndelphine All Ford Techboard 9 05-14-2005 06:37 PM
misfire help ccso640 All Ford Techboard 4 02-21-2005 02:08 PM
351C Vibe & misfire.. ZRX61 All Ford Techboard 9 02-09-2004 08:40 PM
Holley
