05-27-2008, 07:11 PM   #1 (permalink)
welchj69
engine swap help/info straight 6 to 351 cleveland
i have a 1977 ford f150 4x4 with a straight in it i am installing a 351 Cleveland in it need to know if the engine mount converter kit for the 351 Windsor with fit the 351 Cleveland
also will i need to change the headers on it or can i keep it stock ?
any help would be great thanks
welchj69 is offline   Reply With Quote
05-27-2008, 07:58 PM   #2 (permalink)
hoofkicker
Re: engine swap help/info straight 6 to 351 cleveland
If i was doing swap, i would get motor mounts, oil pan and pickup out of 1979 f-150 4x4 with 351 modified.This is the simplest and cheapest way.The manifolds off the modified well also work. If you are planning on using electronic distributer, same donour engine or 460 well work.
hoofkicker is offline   Reply With Quote
Need info on 351 cleveland rods fairlaneragtop All Ford Techboard 2 01-19-2008 07:28 PM
Advice for my 351 cleveland? All info appreciated rem308 All Ford Techboard 39 01-20-2007 03:11 PM
Some questions about Cleveland head swap and engine rebuilding. sharpshot71 All Ford Techboard 9 03-01-2006 02:32 PM
More Info on this Cleveland EFI Intake Manifold 1 Bad 88 GT Late Model EFI Techboard 7 08-08-2004 11:21 AM
Aus EFI cleveland info wanted IsoRivolta All Ford Techboard 0 06-20-2003 06:27 AM
