05-30-2008, 11:36 AM   #1 (permalink)
Tex
What rear gears for a 302 F150?
Small blocks are a somewhat new to me. Can anyone tell me what a good fuel economy rear gear would be in a 79 F150 that is getting a 302? The 400 is worn out and I'd like some better mpg's so I'm going with a smaller engine. It seems to me the stock 2.75 rear is way too high for a little 302 economy engine. I've got either a C4 or a C6 to go in. No AOD on hand. It's just gonna be a daily driver, not much hauling. Would I get better mileage out of staying with the 2.75 and dropping in a 351W?
Thanks for any input,
Tex
Tex is offline   Reply With Quote
05-30-2008, 06:11 PM   #2 (permalink)
chas319
Re: What rear gears for a 302 F150?
With the 302 a 3.55 gear would be good with a 30" tire.
82\' F150, 6\" lift, 35\'s, 4.11\'s and locked. C-6 shift kit. 347, AFR185\'s w/ all the other goodies.
93\' Ranger 4.0 Auto, stock daily driver.
chas319 is offline   Reply With Quote
05-30-2008, 08:23 PM   #3 (permalink)
frdnut
The 351 might get better mileage..Especially with a 2.75 gear..I went from that exact setup getting 10mpg to swapping in a 429 thunderjet that got 12-14mpg and had 10 times the power...I would go with no less than a 3.00:1 gear with the 302..
06-03-2008, 06:20 AM   #4 (permalink)
Tex
Thanks for the info. What sounds ideal is if I could find an AOD to drop in with the 351W.
Tex
08-17-2008, 06:45 PM   #5 (permalink)
scooba_guy
I had 3.07 gears in my '90 f-150 with the 5.8L, upgraded to 4.10's after lifting it and putting on 35" ers. but then again i have an e4od; in your case I would stick to something in the 3.23-3.55 range. especially since you are considering a non-od tranny.
scooba_guy is offline   Reply With Quote
Latch for f150 rear window ShotRod64 The Garage 2 01-17-2008 06:47 PM
95 f150 rear drum breaks DominickSch All Ford Techboard 7 01-12-2008 05:41 PM
Bangin gears with an f150 5-speed james302 All Ford Techboard 10 12-17-2006 09:57 AM
79 4x4 F150 Rear end questions sinistertrucker Truck Forum 2 07-12-2005 09:15 PM
F150 rear end gear swap mavman All Ford Techboard 1 06-06-2003 08:02 PM
