06-10-2008, 10:47 AM   #1 (permalink)
ibrm155
302 in a ranger
my grand father has a 1989 ford ranger it has a 2.9 v6 in it but i want to but a 302 but not sure what i need. Do they sell motor mounts or do i need to buy a new k member. i know i need to but a bigger rear end. i want to run a stroker 347 motor and a c4 trans with a 3000 stall but do i have to hammer the fire wall to fit the c4 and do the sell i trans mount for this applcation or do i have make my own.. im almost sure ill have to get a custom drive shaft.
has any one done this before??
i dont plan on drive this pickup every day but i do want it too be street legal
ibrm155 is offline   Reply With Quote
06-10-2008, 03:12 PM   #2 (permalink)
94_ranger
Re: 302 in a ranger
I've done a couple of these swaps, and they are actually pretty simple. You will need the following.
Ranger swap motor mounts (I have some for sale)
Ranger swap headers
Oil filter relocation kit
C4 with the 157 tooth (small) bellhousing
8.8 rearend
And your stock Ranger driveshaft WILL WORK, you just have to get a C4 yoke for the driveshaft
Plan on the actual swap taking about 75HRS. If you need to know anything else about the swap just PM me, I can even give you specific part numbers you might need. Hope this helps!
94_ranger is offline   Reply With Quote
07-11-2008, 11:23 AM   #3 (permalink)
Wade S
Re: 302 in a ranger
Originally Posted by ibrm155
...1989 ford ranger 2.9 to a stroker 347/C4... Do they sell motor mounts?... bigger rear end?... hammer the fire wall?... trans mount?... custom drive shaft? Has any one done this before??
Yes.
Ford Ranger V-8 Engine Swap - not the Conversion Bible, but the entire tech library is good info.
V8 Tech - Ranger Power Sports Forum This forum is HP oriented.
V-8 Conversion Forums - The Ranger Station Forums This site is more 4X4 oriented, but the V8 forum is great.
Don't forget to search before you post. Nobody likes an irritating newbie starting threads that've been started before!
Search for "vert mounts" -- that will get you started.
4.0L mounts w/ fabricated adapter plates work, too.
I'm "Wade" there, also. See ya' there. Find me, PM me. I'd be glad to help you around the sites.
'89 Ranger 5.0L Conversion in progress, '85 Crown Vic Electronics - CFI - Edelbrock intake - Patriot Headers, otherwise stock. intended Daily Driver.
Wade S is offline   Reply With Quote
10-27-2008, 08:05 PM   #4 (permalink)
oxidejunky
Re: 302 in a ranger
i just used stock mustang convertable motor mounts and redrilled and sloted the k member. the angles of the mounts and the k member are so perfect its like it was meant to be. Also i have a aod behind mine and i used the stock mount for that and just had to move the crossmember ahead. the biggest problem i have had was with the steering shaft to header clearance.
oxidejunky is offline   Reply With Quote
11-08-2008, 12:30 PM   #5 (permalink)
MCCUTCHEON4
Re: 302 in a ranger
Do you have any pictures of your mounts in the chassis? Duff mounts suck.
MCCUTCHEON4 is offline   Reply With Quote
400 into ranger lilman All Ford Techboard 26 11-20-2007 11:45 AM
Anyone here put a 302 in a ranger? kymadan Home Porting Cylinder Heads 3 11-11-2006 12:48 PM
Anyone here put a 302 in a ranger? kymadan Truck Forum 24 10-23-2006 12:21 PM
302 into 85 Ranger 4X4 With C5 tankama Truck Forum 4 02-02-2006 03:13 PM
87 ranger....help! bandit Truck Forum 3 07-20-2004 12:59 PM
