Check the coil (-) terminal for pulse with a test light while you crank the engine, if the light doesn't blink, the module may be fubar'ed. To check the D-Spark stator sensor, using the diagram below, disconnect the 4-wire connector from the module and measure the resistance between the wires at the distributor connector that mate with the Orange and Purple wires of the module. If the resistance is not between 400Ω - 1300Ω..... the stator sensor needs to be replaced.
