Re: 77 Ford F-100 460 Install - Engine Angle
Yes, normally it would be a front sump pan installation. Engine is actually a 460 stroker (521 cu in.) and most everyone I consulted with including the engine builder recommended an extra capacity oil pan. The only way to achieve this was with a rear sump pan. Theres not enough room in the front. Pan is a Moroso unit. I guess the point I was originally trying to make is, I've only raised the front of the engine a little over a quarter inch or so, 5/16ths by my measurement. Should I be worried about the engine angle enough to raise the transmission or just install the wedge plate and be done with it?
RK
65 Mustang 289 - Forged Pistons RPM Air Gap 650DP AOD Tranny 9 inch trac-lock w/ 3.50 gears Solid Lift Cam Hooker Headers MSD Ignition Sub Frame Connectors
