09-24-2009, 11:25 AM   #1 (permalink)
Drbdenglish
Carberator idles at start, then won't stay running until engine is hot. Ideas?
I have a 1968 Ford F250 with 360 cu. in. bored .30 with 8.5 to one pistons, edelbrock CJ alum. heads, high rise dual plane intake, 1 7/8 in headers, edelbrock cam to go with the top end kit (lift around .590) running a rebuilt 750 duel line, vac. choke, with 2 inch torq spacer between the carb and intake. I can't get the car to idle no matter where I set the chock, until the engine is fully hot 180 degrees. I have tried various adjustments to the primaries, idle screws, even turned up the idle, but that's 2,000 RPM before it will stay running without tapping the pedal. Any ideas on what to check next?
Drbdenglish is offline   Reply With Quote
09-24-2009, 12:42 PM   #2 (permalink)
Re: Carberator idles at start, then won't stay running until engine is hot. Ideas?
Take the carb off and clean it out.
Honor!
09-27-2009, 12:21 AM   #3 (permalink)
huntsman53
Might be a bad choke or loss of vacuum (leak and plugged line).
Frank
huntsman53 is offline   Reply With Quote
10-27-2009, 10:13 AM   #4 (permalink)
Lngbeard
Have you taken off the choke stove and ducting? My Holley has problems with carb ice during warm up because I removed the choke stove set up. Just a thought.
Lngbeard is offline   Reply With Quote
10-27-2009, 10:28 AM   #5 (permalink)
Holley's Ice up during warm up? I've never heard of that.
Not like it matters, this tard ain't never coming back... He probably forgot his password and forgot where he put up his question...
Honor!
Help! My Stang will not stay running? SEE SYMPTOMS yella29 Mustang Pages (1965-1973) 17 02-15-2009 05:42 PM
'65 won't stay running zpyro Mustang Pages (1965-1973) 13 05-12-2008 11:10 PM
Overheating Again - Running out of ideas rkingston All Ford Techboard 27 08-13-2007 10:20 PM
First time engine starting, wont stay running. Need Help strtcar All Ford Techboard 8 04-07-2007 04:52 PM
Wont stay running fender2k5 Late Model EFI Techboard 1 10-14-2004 09:10 AM
