10-08-2009, 07:53 PM   #1 (permalink)
smokee153
Exclamation Need Some Advise A.s.a.p.
I need to swap AOD tranny's in my 89 bronco 4x4. everything was fine until I went to remove the torque converter and can't get the nuts to budge! I managed to get one loose but now the other three are stripped!!! Any advise on getting the torque converter off now?
smokee153 is offline   Reply With Quote
10-08-2009, 08:37 PM   #2 (permalink)
JD66Falcon
Re: Need Some Advise A.s.a.p.
I would say try the next size smaller socket and try to tap it on. Then use some heat on it if you have a torch. You could also try a vise grips on them. Last resort is go to Sears or a local tool seller for this...
http://www.sears.com/shc/s/ProductDi...q%0AhxpFuN4%3D
1966 Falcon 306
1993 Bonneville SSEi Lots of Mods
JD66Falcon is offline   Reply With Quote
10-09-2009, 08:30 AM   #3 (permalink)
That's ALL you can do.....
Should have used a bigger hammer....
Honor!
newbie needs some advise MrPinto Drag Racing 19 09-27-2008 09:31 AM
Advise On Modifications JFalcon C4 Transmissions 1 04-19-2008 01:57 AM
need advise on 390 dnhracing Galaxie Pages 17 04-10-2006 11:38 AM
haggerty pls advise trukstopcowboy All Ford Techboard 12 11-09-2005 03:27 PM
Getting old car rdy for use ........need advise PONY1 All Ford Techboard 0 04-18-2002 03:55 PM
