10-23-2009, 06:35 PM   #1 (permalink)
77f100
460 swap
i have a 77 f100 with a 302. i'm swaping out for a 460. i've read somwhere someone said the used a set of moddified 390 mounts. i wanna do the stock look conversion. not wanting to use l&l mounts. so what mounts do i need to do the swap?
77f100 is offline   Reply With Quote
10-23-2009, 06:46 PM   #2 (permalink)
fordman460
Posts: n/a
Re: 460 swap
F250 form '73 to '79. Came with 460's. Get all three parts. Frame stands, insulators, and block brackets..
10-23-2009, 07:12 PM   #3 (permalink)
77f100
Re: 460 swap
well i tromped through the junk yards today and i couldn't find a truck with a 460. well actully couldn't even find a 460 period. is there anyother frame stand that would work? or does anyone know where you can buy frame stand online?
10-27-2009, 10:38 PM   #4 (permalink)
colkerr
Re: 460 swap
Have an auto wrecker do a North American search. They'll turn up.
Sassy Grass My Ass
colkerr is offline   Reply With Quote
10-28-2009, 06:13 PM   #5 (permalink)
77f100
Re: 460 swap
thats a great idea didn't think of that thanks for the idea. so would i ask them to search for? 460 frame towers? or is there a technical term for it? or is that the technical term. haha
10-28-2009, 07:24 PM   #6 (permalink)
frdnut
Re: 460 swap
Why not use the L&L mounts?..I used my 302 frame towers and just needed the mounts that bolt to the big block engine..I got the L&L mounts and it was a very simple and straight forward swap after that..I'm doubtful anyone could tell if those mounts were stock or not anyway after the engine is in and the exhaust is on..
10-29-2009, 04:58 PM   #7 (permalink)
77f100
Re: 460 swap
i can use my 302 frame towers if i find the right 460 block mounts? i may just go that route,
10-29-2009, 05:08 PM   #8 (permalink)
colkerr
Re: 460 swap
I'm pretty sure you'll need the 460 towers.
Sassy Grass My Ass
10-29-2009, 05:29 PM   #9 (permalink)
frdnut
Re: 460 swap
It has been a while since I did this but as far as I know there are only six cylinder and V-8 towers..There is no difference between small block and big block towers..The difference is in the mount that bolts to the engine...In response to your PM these are the mounts I used with my 429 and 302 towers that were already in the truck...
L&L Products
C4 swap out mongooztt C4 Transmissions 4 01-13-2009 12:24 AM
4.6 swap superd54 All Ford Techboard 21 03-01-2005 09:42 PM
360 to 302 swap woodyp Truck Forum 5 02-25-2005 10:51 PM
4 SPD to 5 SPD swap anyone? lynched1 Torino Pages 2 01-15-2005 03:39 PM
Are the granada swap just as good as an aftermarket disc swap for mid 60\'s fords chris21 All Ford Techboard 11 07-10-2003 11:32 PM
