91 T Bird, Aluminum 347, 6 speed, Baer Brakes
Is there anyone interested in my American version of the M8? I bought new in 91. the chassis has ~80k miles, always garaged. The motor and trans are new. The aluminum block is 4 bolt, sleeved 5.0L made for Ford by RDI. Aluminum GT40 X heads, GT40 intake, steel crank , h- beam rods, E 303 Ford roller cam, Danny Bee block saver and double row t chain, 10-1 pistons, 1/2" hd studs, copper hd gaskets, Melling oil pump, adjustable roller shaft mount rockers, factory pushrods, new water pump, timing cover and fasteners. 70 mm throttle and air flow meter, 24 lb injectors. New flywheel and clutch. New T-56 Borg Warner, Aluminum radiator, oil cooler, braided lines. Bilstein Eibach 13.5" Baer 4 piston brakes, drilled slotted. Independent rear suspension w aluminum lower control arms from lincoln. New driveline u joints, Good matching Dunlops, Good Interstate Batt, more. many more pictures and details available for those interested May consider parting or trade. Call Randy 760 471- 5474 San Marcos CA
Reason: adding pics
