Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Wheel and Tire Articles
03-13-2008, 08:37 PM   #1 (permalink)
F15Falcon
Largest Tire & Wheel For '72-'76 Torino
What is the biggest tire that will fit in the back of my ’72-’76 Torino? I’ve seen this question asked on several forums Including Fordmuscle. Since I am going to be installing 15” tires and wheels on the back of my ’73 Torino Sport, I decided to answer this question for myself and to help others. My first choice was going to be 15 x 8 Magnum 500’s with a 295-50-15 tire. A couple of questions to resident FM Torino guru Jon Mikelonis revealed that a 10” wide wheel was possible. The backspace on the 10” wheel would be 5” according to Jon. He even suggested that 5 ½” would be even better. I wanted to know exactly as I was itching to order some wheels. I make some quick measurements and found that the 5 ½” backspace would clear, but it was going to be close. I needed to mock up an actual tire and wheel. A little rummaging through my wheel pile turned up an old Firestone 15 x 10 Nascar wheel that was given to me by Richard Petty at P.I.R. when I was 12 years old. It was the right width, but was a 6” backspace, ½” more that I needed. A ½” spacer would put me right a 5 ½”, so it would work. I was also going to try another combination that I have used on Street Rods and pick up trucks for years. That combination is a 285-70-15 tire on an 8”- 8 ½” wide wheel. It is a monster tire and wheel combo that has a different look from the 295-50. The wheels were a pair of Minilites that were 8 ½” wide, with a 4 ¾” backspace.
I tried the 295-50 combo first, expecting to have to put a spacer to allow it to clear the frame. Much to my surprise, the 295-50 with the 6” backspace wheel cleared everything perfectly!!!! I was worried that the 5 ½” backspace wheel would be tight, and the 6” cleared great. The area that I was worried about was the frame rail clearance between the tire sidewall at the front of the tire. The was ¾” of clearance between the frame and the sidewall. The outside wheel lip had ½” between the sidewall at the stock ride height.
Here are the vital stats on the whole combo:
295-50-15 Mastercraft radial tire.
-Tread width-10”
-Section width-12 ¼”
-Height-27”
-Wheel width-10”
-Backspace-6”
-Frame rail clearance-3/4"
-Wheel lip clearance-1/2” *
*At stock ride height.
Side view of the 295-50
Back view.
Frame rail clearance.
This is a view from the undeside.
Next on the list was a 285-70-15 Bf Goodrich tire on a 15 x 8 Minilite wheel with 4 ¾” backspace. This tire has a totally different look because the tire is so tall. This combo cleared perfectly also with ¾” between the sidweall and the frame, and 1” between the outer wheel lip and the sidewall
Here are the vitals on this combination:
-285-70-15 Bf Goodrich radial tire
-Tread width-9”
-Section width-11 ¾”
-Height-30”
-Wheel width- 8 ½”
-Backspace-6”
-Frame rail clearance-3/4”
-Wheel lip clearance-1”
285-70-15 side view.
Rear view.
Underside.
Conclusion:
Both combinations fit well with plenty of clearance. The 295-50 tire will look way better with the Magnum 500 wheel, as the stock car wheel looks too bland. I may try a 255-70-15 tire on the 10" wheel with the 6" backspacing as a taller tire(though not as tall as the 285-70) might look even better than the 295-50. A little measuring told me that there was no way the 285-70-15 would fit the car with a 10" wheel.
03-14-2008, 11:59 AM   #2 (permalink)
falconrun
Re: Largest Tire & Wheel For '72-'76 Torino
I've run 15x8 with 275/60 on the back of my 72' and it looked real good. They have good height and width. Kind of a compromise between your 295/50 and the 285/70. Currently I'm running 17x8 with 275/50/17 on the back with 255/50/17 on the front. They fill everything out real well with plenty of clearance. These cars look great with fat meats out back!
falconrun is offline   Reply With Quote
03-16-2008, 09:25 PM   #3 (permalink)
eliteman76
Well, there is a black 72 GTS locally that I have seen, and they are running a 305/50/15 out back, and man it fills up the wheel well.
Up front, it has a slightly narrower tire, a 295/50/15.
I have a picture in one of my albums, of a '72 GT Montego running mopar police steelies, 15x8" with 295/50/15s all around, simply killer. I also recall in high school a kid running an Elite with the same setup, black stock car rims, and bfg's.
My only issues with running such a wide tire out front, was on my '84 F150, I had 10" rims on BFG 295/50/15's, and the thing had a habit of grabbing the ruts in the road at times.
eliteman76
1973 Torino GTS
1979 F150 4x4
03-17-2008, 08:57 AM   #4 (permalink)
F15Falcon
I believe the 305-50-15 and 315-50-15 have been discontinued as I have not been able to buy any for the last several years. You can still get a 305-50-16, but I figured most people would want to stick with 15" wheels, The 305-50-16 is a monster.
03-19-2008, 10:10 AM   #5 (permalink)
blown68
Smile Re: Largest Tire & Wheel For '72-'76 Torino
I am assuming the '72 Torino would be similiar to a '72 Country Squire wagon wheel well? I would also like to put some fat rubber on the rear with some Magnum 500s. I was thinking of a 295/60R15 would look good under that land yacht of mine and some 235/60R15s up front to finish it out.
[img]http://i226.photobucket.com/albums/dd91/blown68/cruise.jpg[/img]
blown68 is offline   Reply With Quote
03-19-2008, 10:19 PM   #6 (permalink)
falconrun
I put an attachment of my Torino with 275/50/17's. I've got some others with the 15's...sometimes I hate computers.
01-24-2009, 09:25 AM   #7 (permalink)
baj50
i have a 1973 gran torino sport. ihave 235/75R15 all around. this an optioal size.will this throw off the spedometer reading when going down the road?
hey! new to forum. i have a 1973 ford gran torino sport,400c.i. 2-barrel.all original.i am looking for power steering hoses.saginaw pump.help.
baj50 is offline   Reply With Quote
HTML code is On
largest 4 lug wheel and tire Rons66GT Mustang Pages (1974-1978) 7 03-08-2007 03:39 PM
1970 Torino wheel and tire size ragtoptorino Torino Pages 4 12-29-2006 07:14 PM
Largest Tire/Wheel Combination coolreed Mustang Pages (1979-1995) 3 08-29-2006 08:31 AM
Largest wheel/tire combo under 71-73 472Mach1 All Ford Techboard 9 02-27-2005 04:30 PM
largest wheel and tire size combination for 72 gran torino sport fastback dtitus Torino Pages 6 10-07-2003 02:06 PM
